ron_dittmer
May 06, 2019Explorer III
tatest wrote:Yep!
You want GVWR 1500 to 2000 pounds more than empty weight of the RV. Much less than 1500, you tend to overload. A whole lot more than 2000 pounds, ride will be rougher unless you can load close to GVWR; it is not like air suspensions, which adjust actual spring weights to a ride height.
When loaded up (your heaviest scenario) you want to be close to your chassis GVWR. Doing so will provide a reasonably comfortable and tolerable ride. Otherwise driving on poor road surfaces, it will feel like you are driving an empty box truck with loose houseware lying on the floor, and if you are not careful, you could chip a tooth or bite your tongue. Your cup holders will be useless because your drinks will never stay in your cups....maybe your cups will not stay in the holders. In such a case with a short & light weight RV house on an E450 chassis, get the springs modified to consider your actual load to get that smoother ride.
