- pnicholsExplorer II
ron.dittmer wrote:
Desert Captain wrote:
The 55 gallon tank is also useful when boondocking for extended periods because the generator uses the same fuel from that tank. Even with our 55 gallon fuel tank, we fuel up near our destination to have more fuel on-hand to run our generator. In a few places, it would be "testy" with a 40 gallon tank.
The 55-gallon tank was an option on the E-350 and most folks wisely optioned for that vs the 40-gallon standard tank. I love the extra range and fueling {vs price} options it gives us.
Good point Ron ... we do the same.
Even with our big built-in tank, we carry along another 2 gallons in our gas can for our portable generator that could be off-loaded into the big tank in an emergency.
However, we did head out into the middle of Nevada once with marginal fuel in the big tank. We luckily found one lone station way out there and - gulp - filled up the big tank at their $5 per gallon price!
BTW, I wonder how many Ford E350/E450 55 gallon tank RV owners know that whenever they think that they are filling up their big tank that they're probably NOT getting 55 gallons into it? Our 55 gallon tank will take another 5+ gallons whenever I "fill it up" - if and only if I use the trickle method near the end of the filling process. - ron_dittmerExplorer III
The 55-gallon tank was an option on the E-350 and most folks wisely optioned for that vs the 40-gallon standard tank. I love the extra range and fueling {vs price} options it gives us. - IAMICHABODExplorer IIIThe OP was asking about a 24 ft and they all come with that choice in the link I provided.
A very large and heavy Leprechaun like yours only comes on a Ford Chassis. - GeezeExplorer
IAMICHABOD wrote:
If you are looking for better ride quality,no problems with the front end and larger and more quiet cockpit area in a 24 Ft Class C the clear choice would be one built on a Chevy Chassis :B
I don't think manufacturers give the option to choose which chassis you get? I know we didn't have that option when we ordered our 2019 Leprechaun. - Desert_CaptainExplorer IIIThe 55-gallon tank was an option on the E-350 and most folks wisely optioned for that vs the 40-gallon standard tank. I love the extra range and fueling {vs price} options it gives us.
:C - Dusty_RExplorerOur 24V Itasca on a 2001 E-350 had a 55 gallon gasoline tank.
- whemmeExplorer IIDid someone mention that the E450 chassis uses a 55 gallon fuel tank and the E350 chassis only has a 38 gallon tank.
- bobndotExplorer IIIGjac, BTW, when I bought my new rig last year, I was scraping the rear hydraulic jacks on driveway aprons. I had to have the mounting plates cut shorter in order to raise them to gain some clearance. All is fine now.
- Desert_CaptainExplorer IIII never had any need for air bags until I got my cargo trailer for the motorcycle. The extra tongue weight of the single axle trailer would drop the rear end about 2”. I added the Air Lift 5K air bags and it resolved that issue.
With just 50# the hitch height returns to 16” with the tongue dead level. To my surprise when not towing I put 20# in and the great ride I always enjoyed got even better... go figure? Don’t have a built in compressor but both air lines run to a single Schrader valve and my portable compressor tops them up nicely.
:C - bobndotExplorer III
I assume that air bags hold their air perfectly so that if I use them for leveling at campsites ... their lifting height would stay fixed at what I set it at when staying at any given campsite day after day.
The bags will hold the air pressure unless a line connection is not set correctly. Test them with a soapy solution and a spray bottle as you would test a tire. Mine would lose a little pressure over time when parked in my driveway for weeks or months at a time, I found that to be normal.
How you described the two air lines and switches is the way I did mine in the past. When using them that way to level the rig at a campsite, it might be all you need to do. Depending on the terrain of each site but most of time the bags did the trick.
38,773 PostsLatest Activity: Apr 23, 2026
