JcWhitney.com and
summitracing.com both sell several DeRalle transmission coolers.
Look for a flat plate design. Install it after the factory transmission cooler. Look for one rated at around 20,000 GVWR, and it should do the job. They install quickly with quick connect push on fittings and a hose clamp, with flexible lines, and inlet and outlet can be reversed to keep the lines shorter, or prevent it from kinking.
When you click on the website above, look for or search "Transmission cooler" or DeRalle. Either should find what you are looking for. Your local auto parts store might have them too - no shipping cost either.
Also was your engine overheating too? My 97 with a 460" engine does not overheat on the hills, and I have a digital temp gauge on the transmission too. IT normally runs around 180- 195F and on a hill might reach 215F for a short time. But that is in the normal range.
How hot was yours getting on the drive back home?
If the engine is also overheating, then have you heard the fan clutch kick in? That could indicate that the fan clutch is bad. This can lead to the radiator overheating, and that is where most of the transmission heat should be going - the cold side of the radiator. It has a 30,000 Btu heat exchanger built into the side tank. The stacked plate heat exchangers are a bit smaller in heat capacity.
Fred.
