vqarabs
Oct 12, 2013Explorer
E40D problem?
I was about 150 miles into today's return trip home from the Oregon Coast when all of a sudden the motorhome started lurching a little bit. My first thought was fuel pump, but the 460 FI was running fine. So I pulled over on I-84 and checked tranny fluid. It appeared to be low and I ended up adding a quart. Took off slowly and got to Hood River and decided to pull over and check again. Couldn't get a good reading on dipstick, but was a bit sluggish moving the lever through the gears. Slowly added a couple more quarts and finally it appeared I could see fluid on dipstick. Took off again and kept it under 60 but climbing out of the Gorge the tranny shifted from OD to Drive and all of a sudden I had lurching again and then I saw lots of white smoke going out the back end. Pulled over and shut things down for 30 minutes. Inspection didn't show any leaking on the ground but did appear like there may have been some fluid on exhaust? Fired it back up and drove 30 miles to Boardman at 50 mph. Seemed okay, so went on to Hermiston for the evening. All gauges read fine, but I'm wondering if I have a damaged tranny. It's 30 miles to Tri-Cities WA, but lots of hills between here and there. Don't know if I risk it or get a rental car here or what. Am pulling a small aluminum boat - but not a lot of weight to it. I should add I'm not getting funky noises from tranny nor is it shifting hard or funny or anything.
Any ideas? Thanks in advance.
