j-d
Jul 08, 2018Explorer II
E450 Alignment with FOUR Degree Adjustable Bushings
Background: 2002 Front Axle, Radius Arms and Brakes replaced with Same from a new 2012 E450 being converted to 4x4. I did NOT replace the Springs, so they are OEM 4600-lb from 2002. I also did NOT change alignment, rather I installed the 2012 axles with their factory Ford bushings. RV sits and rides nose low. Drives relatively well.
Project: Replace OEM 4600 springs with 5000 SuperCoils to increase axle capacity to 5000 and improve ride height.
Problem: Raising the front of a Twin-I-Beam Suspension does NOT increase the Caster Angle as with a double wishbone design. It actually REDUCES positive Caster. My guess is the 2012 axle was configured for that "default" 3-3.5* and the low ride height increased it to 4* or so. This can be corrected with adjustable Caster/Camber bushings and this is how I plan to do this as part of the Spring Upgrade
Plan:
1. Remove OEM "Camber Bushing" (retains upper ball joint), place on Cardboard and Spray Paint the outline of its footprint, including the Center Hole, noting the Index Tab (which also has a notch for Pinch Bolt, can't fall out if Pinch is only loose, Pinch has to lose its nut and fall clean out before OEM Bushing can escape). Do this for Driver and Passenger Side Bushings.
2. Match an Adjustable Bushing to each of Driver and Passenger paint patterns. Done by orienting the Outer part of the Adjustable to the Pinch Bolt notch AND turning the Inner part within the Outer.
3. Consult the Chart that comes with Adjustable Bushings. De-Code the meaning of the setting made in 2.
4. From position in 3. consult Chart and find a setting that adds the most Caster to setting from 3. without disturbing Camber.
5. Install Adjusted Adjustable Bushing in same orientation as OEM bushings. This should add Caster to the OEM angle.
Oh. Step 000. Pray a LOT first!
I hope I can measure Caster and Camber using an adjustable Level, and decode to Degrees using a formula Harvard sent me. AND that I can adjust the Bushings with Wheels in Place and Tires on the Ground. I bought two sheet "Teflon" cutting boards. Plan is to grease between them, pull up onto the greasy board sandwich, and be able to tweak the position. Like the floating plate on a Rack.
My reading up tells me the Ford Van is set up with very little Caster, +3* being the center of a range that runs up to +7*. The result of +3* is Oversteer. Steering moves off center then moves still farther than wanted. Purpose of all this is add +2* to +4* changing the characteristic to Understeer. Resists going off center by shifting steering axis farther forward of Tire Contact Patch. Distance from where Axis meets Road to where Patch centers on Road is called Trail.
Most OP's have done this job with Ingalls "594" bushings. The equivalent from Specialty is SPC 241810. Both of these can adjust Caster by about 2* to 2-1/4*. I'm interested in bushings that can go to 4* because I don't know what the actual alignment actually is, let alone what it'll be when the ride height increases with the new springs. That's why I'd like to have the 4* adjustment range available. NAPA NCP 264-3950 and probably ACDelco 45K6525 and Moog K80109 are other 4* bushings. I went to NAPA today and used my phone (no copier available) to copy the basic instructions and the degree chart for 2WD Fords. I also looked at a 264-3950 bushing and was surprised to see it's a two-piece bushing. I'd thought it might be three-piece somehow to allow for more adjustment range, but it's not. What I think that means to me, is that it'll be tricky to dial in since each degree of twist is twice the change it would be with a 2* bushing. Here are the two photos.
Your thoughts, please...?
Plan:
