Vulcan_Rider
Jul 30, 2015Explorer
Biggyniner wrote:
Tire pressure I run 70 psi in the front and 65 psi across the rear.
As far as caster settings, I don't know, but there is no aftermarket caster adjustment on it.
How did you arrive at those pressure settings ?
Before you do anything else, you need to get them to the recommendation. Different rig but mine is 65 front and 80 (dual) rear.
After that, an honest alignment shop (good luck with that) which has some experience with the E-series class C's should be able to inspect the ball joints and "fix" the alignment. Cost me about $350.
I still haven't driven mine but given the glowing reports from a LOT of other owners I don't expect to be disappointed.
