j-d
Jul 30, 2015Explorer II
b9r, what year is your E350? Would also know RV length, wheelbase. Also, can you go weigh this coach? Corner weights are best, but axle weights Front and Rear (truck scale will call them Steer and Drive) will work for tire pressure planning. You don't need to add pressure just because you went from D to E. 65 Front is for max axle load on a C with 4600-lb front axle. What's the tire size?
