Biggyniner
Jul 30, 2015Explorer
j-d wrote:
b9r, what year is your E350? Would also know RV length, wheelbase. Also, can you go weigh this coach? Corner weights are best, but axle weights Front and Rear (truck scale will call them Steer and Drive) will work for tire pressure planning. You don't need to add pressure just because you went from D to E. 65 Front is for max axle load on a C with 4600-lb front axle. What's the tire size?
Its a 1994 E350 with the 460v8. Length is 22.5 ft (its the RB421 Minnie Winnie). I believe the tire size was 245/75/16 but it may have been 225.. Can't recall exactly..
