i have a 2012 6.0 vortec 6 gear trans that can be controlled on the shift lever . i drove truck and now how to use gears and rpm to run hills . i get a lot of comments on the ford about down shifting ...
I don't know what beginning year "new" refers to regarding the F250, F550, F650, and F750 models, but as I understand it the really big change to the 5-speed (with 6 internal ratios available under certain temperature conditions) computer controlled 5R110 TorqShift transmisson with the Tow/Haul mode was first introduced in the E-Series vans in model 2005. Some years after 2005 the E-Series vans were fitted with a transmission that uses 6-speeds all the time.
