Chum lee wrote:
the2sharps wrote:
I share the following experience as a heads up. I have a 2012 Class C motor home on a Ford E450 chassis. The fuel system developed a leak when I pumped gas into the tank. The leak was coming from the fuel filler pipe hose that runs through the frame and clamps to the gas tank. The filler hose was factory installed. I took the motor home to a shop for repairs. The mechanic replaced the 10” piece of hose that runs from the tank through the frame and joins to another section of hose about 11” long. The mechanic showed me the old hose he removed. The hose was in really bad shape and had many cracks. There were several long deep cracks on the top of the hose about 4” from the end that clamped to the tank. Those deep cracks were leaking gas when I pumped gas into the tank. The 11” section of hose is fuel grade hose and is fine.
IMO, you are right on the edge time wise. (emissions warranty) It is a MAJOR emissions issue to vent/drip unburned hydrocarbons (gasoline) in the USA environment. (in addition to a serious fire hazard) Without seeing it, it is unclear whether the filler hose is provided by the coach builder, or, by Ford. In any event, an 8 year old gravity flow fueling hose SHOULD NOT LEAK vapor or liquid.
Chum lee
Chum lee, I agree, a fuel leak is very serious. I was shocked when the mechanic showed me the very degraded piece of hose that was leaking and said that it was actually hydraulic hose and not fuel grade hose. That is very concerning. Is this an isolated situation or an RV industry-wide issue? I can't believe that it is an isolated situation, that my coach is the only one that Ford or Fleetwood installed hydraulic hose as part of the gravity flow fueling hose. Very concerning from an environmental and safety standpoint.
