litng1's avatar
litng1
E450 questions
I'm looking for a 26 foot c class with no slides E450.
My budget is 20 grand.Ive found many but my question is in the motors seems my budget gets me the 460 motor or 2 valve v10 i'd really like the 3 valve v10.
I have a 460 in my superduty truck and does well.Is it a huge diff in the 460 and the 2 valve V10? Should I spend alittle more for a 3 valve?
Opinions from guys that have had these engines please.
  • Thanks so much for info guys.I have a slide in camper in a 97f250 460 ci
    Needing more room now
  • I agree with the other replies.
    The V10 2-valve is the only Triton engine available in a van & cut-away van chassis because the 3-valve version is too large to fit inside the engine compartment. The V10 in an E350/E450 is very reliable and also powerful. The only complaint people have with the V10 is that it is very loud when accelerating or climbing, and the passenger floor gets quite warm from the exhaust system passing underneath it. But it is a great engine.
    If you can get a 2008 chassis or newer, easily identified by the current-day dump truck style front grille, you'll have a more capable chassis with regard to the weight it can handle. And I think we would all agree that "weight" is the number-one problem with class C motor homes. By the time you add people, water, food and gear, most are over-loaded.
  • Nothing wrong with the 2 valve V-10. Every E-450 made in the last 15+ years will have one along with most of the E-350's.
    :C
  • Personally, I would go with the V-10. Also, they did not put a 3-valve in the E-series (no room). So that's not an option on a C, unless you go to a class A.
