carringb
Sep 29, 2014Explorer
pnichols wrote:
John, correct me if I'm wrong ... but along with the 4R not having 5 external speeds, I doubt that the 4R has six internal speeds like the 5R does, either?
The 4R100 has 4 forward gear ratios. The 5R110 actually has 6 ratios, but they call it a 5-speed because "4" and "5" are very close together, and it will never sequentially shift between those two gears (unless you activate that shift with a programmer), so they are more like two different "4th gears". 3-5-6 in the 5R110 are the same ratios as 2-3-4 in the 4R100, and those ratios are what the 5R110 normally selects. "4th" in the 5R110 is slightly under driven (and used only when the fluid is cold), while "5th" is direct.
The 5R110 shines when taking off from a launch, because it has a deep 1st gear, and 2nd gear splits the difference of "1" & "2" in the 4R100.
FYI - in both transmission, if you manually select a numbered gear (1, 2, 3) it will not shift automatically. It will only use that gear. You can launch from 3rd gear with the 5R110 if you select that gear manually, but in an RV there probably isn't much use for that. In vans and pickups that helps reduce wheel spin when its slippery.
The 5R110 is a very robust transmission, and can handle more power than the Allison 1000.
38,776 PostsLatest Activity: May 14, 2026
