tarnoldExplorerNov 26, 2019E450 wheelbaseWhen a subject frame is extended, is the wheel base also extended? Ie: drive shaft, fuel lines and everything else under there. I ask because the vin says 158” wheelbase, but the ads for the vehicle...Show More
okiejoeExplorerNov 26, 2019Yes it does change depending on length of coach, my E 450 frame was stretched out to accommodate a 32 ft coach and it has 3 drives lines under it.
Related ContentWheelbase questionWheelbase factorsRide/handling upgrade - E450 / 158" wheelbaseStated wheelbaseWheelbase ratio
