tarnoldExplorerNov 26, 2019E450 wheelbaseWhen a subject frame is extended, is the wheel base also extended? Ie: drive shaft, fuel lines and everything else under there. I ask because the vin says 158” wheelbase, but the ads for the vehicle...Show More
tarnoldExplorerNov 26, 2019Op again. So axle, brake lines possible fuel lines, shock mounts, suspension points all have to be shifted rearward?
Related ContentWheelbase questionWheelbase factorsRide/handling upgrade - E450 / 158" wheelbaseStated wheelbaseWheelbase ratio
