Robt65
Feb 02, 2019Explorer
Either smell in coach
I have a 42 foot 2008 Foretravel Numbus Model, Is there any reason I should be smelling an either type oder in the coach? I am a little concerned. Robt65
mowermech wrote:Robt65 wrote:
suggested I get a hotel for the next couple of nights and then call the plant on Monday and see exactly what they did and the connection to any smell. Sounds like the best idea yet. Thanks for the responses
If the house batteries are in the center of the coach, they should be on a slide-out tray so they can be serviced, as in water check and refill, and terminal cleaning.
If glues were used in the repair work, the odor should be acetone or methyl ethyl ketone or some other solvent, probably not ether.
