Jrny_on's avatar
Jrny_on
Electric blanket controllers and inverters
Has anyone come across electric blankets with analog controllers. We have cooked three electronic controlled ones over the last few years due to what turns out to be a problem with the type of power that comes off inverters. When we are on generator or shore power there is no trouble but if we forget to unplug the blanket when we head down the road and have the inventor on for some reason it cooks a large bit of electronics inside the controller, actually gets hot and smells like cooked plastic and melts part of the controller. My sweetie likes to have it keep the bed warm for her and when we have an opportunity to boondock it leaves her less than uncomfortable for the night which makes for things being testy. Thought maybe a heated throw would work but haven't found one with a manual controller. They all seem to have the auto shut off as a feature which means they will be electronic. Does anyone understand why the inverter power is such a problem? Thanks for any help possible.
  • Thanks a bunch folks. What a great source of information. Will try target and JCP first.
  • Why pay a thousand or more $$ to upgrade the inverter, when there are several companies that still make an analog controller. Check Target and JCP online, as they both had them last year.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    I too would upgrade your inverter, Have not seen an analog blanket controller in 40 plus years.. Though in truth I might have one now that I think of it,, I do not use it, not sure if I have the controller though.. Spotted the blanket the other day, but did not look for the controller.
    There are so many advantages to a PSW inverter though that upgrading is my suggestion.
