LSVLance
Mar 28, 2016Explorer
Electric brake control harness in E-450
Has anyone had any luck finding a factory installed harness plug in their newer E-450 Chassis to plug an electric brake controller (like a Tekonsha P3) directly into?
eTrailer says in a couple of different places that there should be one behind the center part of the dash that this connector will plug right into.
https://www.etrailer.com/p-3034-P.html
I pulled the engine cover on my 2016 E-450 completely out last week and only found this connector up there behind the cetner of the dash, which doesn't match the 3034P plug.
Somewhere I saw that some chassis have a black plug and need a different harness, I think for a Superduty chassis...but I can not seem to find that link again for some reason and the guy at eTrailer didn't know anything about it either.
eTrailer had me look up above e-brake pedal for the grey one also, no luck. Lastly, after I left where the RV is stored they said in some instances....it's under the driver seat also.
My next step unless a better ideal is found before then is to start back at the 7 pin connector, see if there is a wire attached to the brake wire pin...then try to follow it forward. Surely there is but at this point who knows. Hopefully one of you has tried to do the same and can hold my hand to save some time.
Thanks,
Lance
Thanks,
Lance
