Effy's avatar
Effy
Explorer II
Aug 21, 2014
Electric dump valves
In my 29.2 it has a macerator. Usually this means despite having full hookups, I can't leave my grey open (well I can it just doesn't do anything) and have to run out every other day (3 of us) to turn on the macerator to dump the grey and every 4 or so for the black. I thought of doing 2 things, one is tying into the macerator switch and placing another switch inside the coach so I can operate remotely. The second thing, I had heard that they actually make electric gate valves. Wondering if anyone has ever done this or have anything like it. I thought that on higher end coaches you could dump your tanks inside the coach but I have never seen a system like that. I can bypass the macerator but by the time I fiddle with all the plumbing and contort myself into the area I need to, I might as well make it automatic since I can't bypass the black. I love having a macerator, it makes things so much cleaner and easier, but it presents a little added frequency in emptying the grey.
  • Effy....What macerator do you have. The SaniCon has a grey water bypass that will drain your grey water while parked. If you don't have one, you could probably install a bypass as "Executive" noted.
    Here is a photo of the SaniCon unit. You can see a small clear hose going from the dump hose to the unit. That's the bypass.
  • A simple bypass hose will solve your problem. Mine has a small, 1/2" X 4" bypass hose that runs between the discharge hose and the 3" drain hose. I'll post a picture later today. A couple fittings and you're done.....Dennis
  • I had Drain Master when they first came out. It worked great until there was water against the valve, then it would not open. The manufacture sent me a replacement and it worked the same way, would not work with water against the valve. They may have improved the valves by now but I'll never use one again.
  • Effy's avatar
    Effy
    Explorer II
    Effy wrote:
    Roadpilot wrote:
    I can honestly say we've had more problems with our manual gate valves then our electric ones. I suspect that the sample size is too small though to draw a solid inference. (4 manual vs 2 electric)
    So where did you get them, how much and how difficult to install or did they come on your rig?
  • Effy's avatar
    Effy
    Explorer II
    So where did you get them, how much and how difficult to install?
  • I can honestly say we've had more problems with our manual gate valves then our electric ones. I suspect that the sample size is too small though to draw a solid inference. (4 manual vs 2 electric)
    Most people will tell you that leaving the gate valve open all the time is asking for trouble anyway, so don't look at that as a negative even with the macerator. We use the sewer solution. It is what it is, gotta dump the grey more often. It only takes a few minutes ( and with that the grey valve can stay open, we don't do it).
    As you mentioned they do make electric ones. That seems like the answer and extending the switch to inside for the macerator. My question is for those with electric ones , are they trouble free? For piece of mind and simplicity I would lean towards the manual valve. But if I bought a MH that had them, I wouldn't complain :B
