I have a 97 Fleetwood Bounder. I cannot get the Refrigerator to cycle to AC, and the air conditioners will not come on when I am plugged in to shore power. When I run the generator, the air works, b...
Most likely two different problems If the fridge won't run generator power, but everything else works A/C outlets mw Then the electric heating element might be burned out Check the outlet behind the fridge, see if it has power There is also a fuse on the fridge control board for the 120v Sometimes it goes out, but often it is because of a shorted heating element
