GlampinLife
Jul 02, 2014Explorer
I checked the fuse already in the battery control center, it was listed with 3 or 4 other things and used a 20amp fuse, all was good.
I'll check the switch tonight. It acts like that switch is stuck On and when I say On, i mean it's in the position to lock the stairs down.
I'll crawl under the RV and make sure everything is plugged in and connected good.
What confused me was that it works with the ignition switch, which allows me to be able to use the RV. It would just be nice for the steps to go up when the RV is parked as it's suppose to work.
Thanks for the reply, appreciate the tips!
38,769 PostsLatest Activity: Dec 31, 2014
