GlampinLife
Jul 02, 2014Explorer
my bad, I have already checked those, specifically the one marked for the stairs. I'll pull the switch and see if there is power to it.
If there is no power to the switch, could that cause the stair to be "locked" from going up?
What wasn't making sense tonight was after I turned the ignition off and the door was closed, I'd open the door and the stairs would go down. That shouldn't have been from the override that happens when you turn the ignition on and shut the door the stairs go up.
Now one odd thing that happened tonight while testing, just once I shut the ignition off, opened the door - steps when down. I then shut the door and they magically came up! That was the only time though.
Could it be the controller?
38,769 PostsLatest Activity: Apr 04, 2026
