GlampinLife
Jul 03, 2014Explorer
enblethen wrote:
Was there power leaving the switch when in the on position?
Did you try jumpering the two wires?
I didn't test the actual switch but I used a 20amp fuse to hook the 2 wires together. It did nothing. With the ignition off and the power turned on or off (that switch at teh battery center) the stairs did nothing when I opened/closed the door.
I then tried with the ignition on and as before, the stairs worked and ignored that switch (to keep them from extending when you open the door.
38,769 PostsLatest Activity: Apr 04, 2026
