enblethen
Jul 03, 2014Nomad
In the manual it gives the two wires to test the magnetic door switch.
From manual page 8(?)To check the door switch, connect a
voltmeter between the red wire from
the 4-way connector (vehicle half)
and the brown in the same connector
(see Figure 8). The voltage
should be a minimum of 12 volts DC
Your voltage is still low. You should disconnect the connector and read the line coming from the switch.
38,769 PostsLatest Activity: Apr 24, 2002
