dougrainer
Jul 03, 2014Nomad
MMayleben wrote:
The purple wire coming off the controller is spliced into a wire, what does the purple wire do?
I just connected the 2 wires at the switch with a 20amp fuse, still only pulling a few amps at the wire wore in the plug
What I don't understand is those 2 wires at the switch read 0.00 when connected but 1 reads 6.5ish apart.
CUT THE WHITE WIRE AT THE 4 PIN CONNECTOR WITH THE STEPS OUT. Doug
38,769 PostsLatest Activity: Apr 24, 2002
