GlampinLife
Jul 03, 2014Explorer
That battery control center is in the dash as you walk up the steps. That switch panel I showed in the video is just above that panel to access some of the fuses. The power wire to the switch goes behind the dash which is closed off with wood paneling, I dont see a way to take it off. Tomorrow I'll check if it's open down by the pedals on the other side.
There are fuses marked from the chassis battery, so there is a hot wire coming from the battery up to that location that I can tap into. Just put a 6 amp fuse between that point and the switch?
38,769 PostsLatest Activity: Mar 31, 2026
