enblethen
Jul 03, 2014Nomad
The wire should be hooked up so it is shut off by the battery control center, but be hot when it is in the operate mode.
You could add a fuse in that panel.
Since this is only control amperage, you could even jumper off the porch light.
You could try to run back to switch along the same path as the white wire.
Has this been a good learning experience?
38,769 PostsLatest Activity: Mar 31, 2026
