murraymcleod's avatar
murraymcleod
Electric steps won't shut off with switch when retracted!
I just bought a 2003 Itasca 27C Class A and the steps work fine, *except* when I use the switch to shut them off when they are retracted (as they are supposed to stay retracted after this). But they will still extend when the door is opened even after shut-off. When shutting them off after they are extended, they remain extended like they should when door is closed.
I need to get this fixed as I don't want them to extend when I park at my house as they hit the curb and get stuck half-way out. Anyone seen this problem, or can someone direct me to the thread where this might be discussed. I assume these are Kwikee steps (?). Thanks.
  • chuckftboy wrote:
    That is how they are supposed to work. If you want them to stay up when the door is opened, Raise them, turn off the battery switch, then open the door and they won't operate.
    Unfortunately, mine still extend when the door is opened after doing this....not sure why the off switch doesn't turn them off in this situation...
  • Thanks...but the manual implies they should shut off regardless of the position (and it references the exact situation I'm experiencing where you wouldn't want them to extend to hit a curb, etc). Maybe the manual is wrong!?
  • On our 06 Winnie that is how they operate. Turning the step switch off, only keeps them out when door is closed. The steps automatically extend when the door is opened, to ensure that you have a step under your feet, whether or not the door switch is on or off.
    The steps are connected to chassis battery, so that the steps will automatically retract when the ignition is turned on.
    To keep the steps from extending when the door is opened, you would have to somehow disconnect the power to the steps.
    Ken
  • That is how they are supposed to work. If you want them to stay up when the door is opened, Raise them, turn off the battery switch, then open the door and they won't operate.
