dougrainer
Jul 02, 2021Nomad
The is a Temp disc for the electric 12 volt heater in the Wet Bay. You turn on the inside bay water heater switch and WHEN the temp drops below 34 degrees the heater comes ON. Doug
To test it I use a standard PC compressed air can upside down and freeze the disc to verify the electric heater does work thru the disc. 15 years old it may not still work.
