larry_cad
Jul 03, 2021Explorer II
dougrainer wrote:
The is a Temp disc for the electric 12 volt heater in the Wet Bay. You turn on the inside bay water heater switch and WHEN the temp drops below 34 degrees the heater comes ON. Doug
To test it I use a standard PC compressed air can upside down and freeze the disc to verify the electric heater does work thru the disc. 15 years old it may not still work.
Doug, his problem is which of the three wires in the harness should be connected to the two connectors? Looks like he has the red one connected, leaving the blue and yellow to decide on.
