jtrantow's avatar
jtrantow
Electrical component identification and wiring help
I needed to replace the water hose on the power reel of my 2006 HR Endeavor. The hose was shot and the mounting bolts securing the reel had pulled out. I replaced the hose, installed reel with bigger bolts, and propped the reel on some foam insulation so that problem is solved.
But, while I had the wet bay panel removed, I noticed the connector to an unknown component behind the wetbay (near the low side latching controller) was broken off at the crimp. This was approx a month ago and I didn't have any crimp terminals. Now I can't find my photo showing which wire went to the connector. Looks like it might be a temperature switch??? with two connectors. The red wire goes to one terminal. Either the blue wire, yellow wire or both go to the other terminal.
***Link Removed***
If someone with a cut down HR/Monaco wet panel could take a look and let me know what you see it would be much appreciated.
  • enblethen wrote:
    I cut and pasted the URL in OP's second post. Took 10-15 seconds to load.
    I tried that too but it didn't work.
  • I cut and pasted the URL in OP's second post. Took 10-15 seconds to load.
  • Good job enblethen! Where did you get the correct url?
  • jtrantow wrote:
    i'm having problems with links to the photos. Is there a trick to using links to google drive photos?
    Yes, there is a trick !
    The simple solution is to the link icon to just place those links in your post.
  • i'm having problems with links to the photos. Is there a trick to using links to google drive photos?
    https://drive.google.com/open?id=1T18tcjUPlK6ajgVYm8b0IuZQDrncTjte
    https://drive.google.com/open?id=1T0RiRGHBCMgtAyuKFhwbNQtwcLHcJZBk
