subtroll's avatar
subtroll
Electrical Grounding Gremlins
In a fiber glass coach and a steel chassis its not surprising that poor grounding causes many problems...non-retracting steps etc. I'm currently dealing with multiple issues that are probably poor grounding related.
Old but related. Couple of years ago, bathroom light was dim. Multi-meter indicated leads to light had half the normal 12 volts. Grounding the light to a nearby Air conditioning frame restored 12 VDC and a bright light.
Two of my rack and pinion slides are moving much slower than when new. I've assumed its a roller issue but could be low voltage.
A week ago, my defroster fans ran at half speed when both on, normal speed when one at a time. Scratching my head.
Yesterday, after parked 10 days (with inches of rain in Iowa) pre-underway startup, jacks up...all systems go. When I disconnected shore power and started to move, my backup monitor went blank, my dash A/C fan died, lost control of my power mirrors? Radio, CB, Gps and all other dash instruments continued to work fine.
Since our planned drive was only 30 miles with another rig in company and essential systems working fine, I elected to continue and trouble shoot at next stop. I reasoned that it had to be a grounding problem but where are the ground points? 15 miles down the highway (very windy day) the problem disappeared... all systems back to normal.
Are the grounds of the AC and DC systems both bonded to the frame/Chassis and essentially all metal frame parts? If so where? Right now there is no problem (other than my defroster fans)to investigate!
Where should the Exorcist begin?
  • Went through this with a friends MH ground cables looked good from out side but were bad inside. Take some jumper cables attach the Neg. from the battery to the tow hitch loops for break a way chains. If every thing starts working again go to a welding shop and have him make up some new ground cables. If you have problems finding the original ground points make your own.
  • Bought the coach new in 2004. 143k miles and other than these gremlins running great.
  • Did you buy this coach new? Because it sure sounds like it may have been under water at some point in its life!
  • I think you should get a jumper cable and connect to the negative battery, and then to the negative terminal strip in the panel. Usually you will have to put a piece of wire under a screw in the terminal strip and hook your jumper to that.
    If your problems go away, then you have to look at the negative return to the battery. If they don't go away, take off that jumper line, and do the same thing with the positive battery to the positive terminal strip.
    Both of those checks are easily done, and can really assist with troubleshooting by eliminating a lot of wiring.
    The next step is to tighten all connections on both the positive and the negative wires, main feeds, and battery connections.
