Stutch wrote:
CA. Thanks. I made sure here was no feedback. I assumed one side was equivalent to a straight adapter.. Guess I was wrong.
What are the shortcomings if I use both sides, 1 30amp and the other 15 amp as it was designed to do?
Will definitely get the straight adapter.
Thanks
Both sides will work but NOT if the 15 amp outlet is a GFI outlet. Unfortunately MOST modern power poles at RV parks have GFI protected 15 amp outlets so it leaves you very few places to use that adapter. Personally I would return it to Camping World if you got it recently.
