Old-Biscuit wrote:
Only one buss bar would have been HOT so backfeeding would have required some non-normal/unusual connection .......99% not going to happen (nothing is 100% cause somebody WILL do something)
Probably less that 1%. But there could be limited voltage on the neutral due to the voltage drop under higher loads. Not much but it could be to much. And with a open ground or neutral on the connected side you could have 120V on the exposed ground or neutral.
Why take a chance with an exposed male plug on the cheater cord? Or why even use it?
That's why I posted "potentially dangerous situation".
