Racer-X- wrote:
I'm doing some repair/restoration work on a 1995 Fleetwood Flair (built on a 1993 Chevrolet P30 chassis). I'm pretty good with the mechanics of the chassis, engine, transmission, suspension, the "motor" part. The "home" part is foreign to me.
One issue I've discovered (the hard way) is that there's something seriously wrong with the AC wiring in this one. We have it plugged in to an outdoor outlet on his house (GFCI protected). The RV has a 30 amp plug on it, but we've got an adapter to a "normal' three prong, 12 Gauge extension cord for now. We're not running the AC in the unit or anything significant. We haven't even turned on the fridge yet. Mostly, just a "boom box" to listen to while we're cleaning up and dealing with various issues.
Here's the first major issue. When I'm working on the thing, the frame and chassis are live with AC power. If it's plugged in, and I'm kneeling on the ground and I touch anything metal on the frame, engine, suspension, whatever, I get a serious shock, like I stuck a paper clip in an electric outlet. There's no issue if I'm working through the doghouse from inside to work on the top of the engine. The issue is only when I'm on the ground and touch the thing with my bare hands or with a metal tool/wrench. If I unplug the power, there's no issue. Actually, working on the thing with it plugged in is borderline dangerous.
I checked the AC outlets in the RV with one of those plug in analyzers (something like https://amzn.com/B00170KUPC ) and it's reading "Hot/Neutral Reversed" for all the outlets in the RV.
I don't even know where to start to diagnose and fix this. Is there any obvious place where something could be connected incorrectly to cause this problem?
Start at the beginning and work your way to the RV. Check the source voltage. Plug in the cords and check the voltage at the RV with it not plugged in. Next turn off the main breaker in the RV. Remove the circuit breaker panel cover. Plug in the RV. Check the power at main breaker with it turned off. L1 to neutral = 120 volts. L1 to ground = 120 volts. Neutral to ground = 0 volts.
