I’m not sure if this is the right forum or not, to talk about an electrical issue, but here goes. Tuesday (3/18/14) my DW and I took our new (to us) 1995 Carriage Callista Cove, out for our first t...
If they are are the back stab type receptacles, if possible you should change them and use the screw type receptacle. They make a secure electrical connection. The screws will not or should not come loose with the constant heating and cooling of the wire when using high current appliances.
I would start by checking the receptacle that the heater was plugged into first. I also feel that there is going to be a GFIC somewhere before this receptacle. JMO
