Busskipper wrote:
dave_330 wrote:
2009 Monaco Knight only have one half my electrical outlets are working. Had an overload last night, checked the GFI outlet that is working fine. Cant find a fuse or breaker that relates to my problem. Any thoughts?
Might need to reset your inverter - often the overloaded circuit is on the inverter and pops that circuit.
Last but not least you could have inadvertently turned off the inverter.
What ever it is let us know how it turns out.
BOL,
most definitely a tripped breaker on the inverter assuming its not in the main panel
Inverter on or off has zero bearing on the flow through electricity
so no inverter does not have to be on
