Canadian Rainbirds wrote:
dave_330 wrote:
Most of you were right, it was the reset on the inverter. thanks for your help
Glad you found the problem BUT:
What was the underlying cause of the overload? Something that you know happened and have corrected or just a guess?
This would be a good time to check all your AC connections--transfer switch, inverter, breakers etc. Loose connections cause increased resistance which cause increased current and heat.
the underlying cause is called using more power all at once for the size of breaker(why breakers trip)
If I run a toaster at the same time I have 1500 watt heater cut in
mine trips also
