pamo's avatar
pamo
Electrical issue
Have 2006 Fleetwood excursion. First trip and everything seemed to be working ok. Now the right side and front tv and bedroom tv have now power. Seems like circuits are not working. Checked breakers and all seemed to be good. Any ideas?
  • FYI the 'breakers' on the inverter are different than ones you find in your electrical panel. They are usually button breakers. These are very small and easily missed. Look for a button about 1/8" in diameter. Push it in and see if that works....Dennis
  • TV are on your inverter, so likely that is the issue if other breakers are ok.
  • I vote for the breaker buttons on the inverter. I had the same issue with my 2007 Discovery and it took me while to figure it out.
  • Try it on the generator, you could have a leg down on the 50 amp at the pedestal.
  • With everybody else it sounds like a bad or tripped GFI outlet. Let us know what you find.
