Effy
May 08, 2015Explorer II
RLS7201 wrote:
Look in your Battery Control center (some where close to your batteries). On the inside of the cover to your BCC is a wiring diagram. Find the chassis battery disconnect relay and check it for continuity. It has been known to fail and cause you described problem.
Richard
That's what I was referring to but you said it better than I did. I do know that the fix was to bypass the BCC disconnect. Do that and you'll never have the issue again.
