Just found out something worked.. Different topic..
now to this topic:
Converter failure..May be caused by battery disconnect (Generator will not start because house batteries are dead)
May be a tripped circuit breaker.. Check both the breakers on the generator (LIkely one of them) and in your power distribution center.
May be blown fuses on converter (not likely)
may be failed converter (slightly more likely, but only slightly)
Most likely is generator breaker.
Couple of other possibilities including a screw loose.. (Many RVers have a few screws loose..The kind you tighten with a #2 Square Bit in all likely hood.. one of my breakers the screw that holds the wire neded over 3 full turns to tighten).
ANd other things too rare to mention at this time.
