kohlerguyExplorerJun 13, 2013Electrical outlet head scratcherI have a 05 Newmar DutchStar. I'm having trouble with 2 outlets. All other outlets work fine. These two outlets only have about 100v to each one. All others have about 118-121v. The 2 problem ...Show More
BrianinMichiganExplorerJun 14, 2013You say that the inverter gets knocked out. Are the outlets that are at 118-121 volts also hooked to the inverter?
Related ContentElectrical outlet issuesNo power on outside GFCI outletElectric OutletsAdding power outlets in slide with no wiringElectrical Head Scratcher
