zonearc
Mar 31, 2014Explorer
Strange, thought I posted a response.
Maillemaker:
Corroded connectors, loose rivets, fan wasn't working. Spent 10 minutes on it and now its working!
Bordercollie:
The old owners used it as a guest room, and only owned it for two years so I'm not surprised there's a few things. Electrical is fixed, and the water leak is coming from the bathroom so I bet I'll discover a loose fitting and that problem will be solved. So far, I'm hoping we'll be through the best of it shortly. As it is, I'm in this thing for less than $6k so even if I spend $3k on it, I'll be happy. Generator doesn't work, but I'll put $$ that its either the fuel pump or just needs the carb cleaned. One day at a time =)
Maillemaker:
Bordercollie:
