CA_Traveler
Mar 24, 2014Explorer III
"Batteries dropping to 9V in several days indicates that you left a lot of loads on or the batteries are shot. Regardless of their age have them load tested. By 12V deep cycle batteries do you mean marine deep cycle which isn't much different than a starting battery.
You might have moisture in one of the GFI plugs which is causing it to trip. Some good ideas above but regardless you need to keep the batteries charged.
Not all rigs charge the starting batteries from the charger so it could also be bad. On my last rig I added a 2 stage 2A charger to the starting batteries.
38,769 PostsLatest Activity: Apr 24, 2002
