wny_pat1
Mar 25, 2014Explorer
Using 1995 and Parallax Magnetek in the same sentence tells me that your converter/charger is a single stage charger. Same charging power 24/7, and that is not good for your batteries. My guess is you need to replace the converter/charger with one that is a 3 stage charger, for proper battery maintenance. And you need to use something to change the starter batteries also, cause they are probably not being charged. And you need to replace the batteries, and make sure you keep them watered!
38,769 PostsLatest Activity: Apr 24, 2002
