Gjac
Nov 01, 2013Explorer III
Quote(I still have not figured how I got a 12v reading to start with.) It took me a while to understand this also. Just because you have volts doesn't mean that amps are getting through, especially when dealing with an older MH. Each time that I read 12v and something didn't work it turned out to be corrosion in or at the terminal. Several times I cleaned the terminals at the battery, inverter or genset only to find that the wire itself was corroded or loose inside the terminal.
