I have an Holiday Rambler Admiral SE 2003,one of the air conditionner (Dometic Duo-Therm)on the roof top was leaking water Inside. What is the problem? Thanks yves1956
Welcome to RV.net! The GFCI are controlled by 120 volt AC circuit breakers not fuses. Locate your 120 volt power distribution panel, Turn off all circuit breakers, apply light pressure toward "OFF'. Turn on main breaker, then turn on each branch circuit breakers one at a time. Possibility number 2. If you have a large inverter, check for tripped circuit breaker on it. Some have a small round red or white button to reset.
