dadd wrote:
MrWizard wrote:
have you done anything to your batteries ?
is the RV side battery disconnect engaged ?
at present you have NO 12v power to the genset to keep the control, fuel pump etc.. working
you have power only when the key is on , because you are getting power from the ignition side of the chassis/drive electrical,
that is NOT the way it is supposed to work
something has been disconnected or maybe cross wired to the wrong spot
COULD THE HOUSE BATTERIES BE DEAD????????
YES or NOT connected. Onan APU's require a good 12 volt source to stay running. When you have the Ignition key ON, the chassis battery system is supplying that 12 volt source. You may have the coach battery disconnect OFF and may just need to turn the 12 volt disconnect system on. Doug
