I hope you were able to find the panel by now. I would also caution that if you do not have an electric filter/analyzer and there was a voltage sag at the pedestal it can cause you to blow a breaker. Everything in your coach wants watts, so if the voltage drops the current rises to make up for it. Current is the only thing that trips the breaker though. If voltage sages and the breaker does not trip one or more of your appliances will. I will never plug into a campground pedestal without an inline filter/analyzer. Some are not wired correctly or dont get anywhere near 115v when they are full and its hot out or grounds are missing and spikes come through everytime someones air turns on.
