mtnpapa201's avatar
mtnpapa201
electrified rims
I recently bought a 2004 Gulfstream B Touring Cruiser. I was checking the tire pressure today and was plugged in to shore power. I noticed I was getting shocked when I would touch the rim. It was enough to be uncomfortable! When I unplugged the shore power it was okay. It sounds like a wire is shorting out to the frame?? Also, It says in the manual not to use a cheater plug to connect to 15 amp/110. As long as I don't turn on the a/c, microwave or any other high usage appliance I don't see where it would do any damage. Any comments or suggestions?
  • Try turning all the breakers off. Then check for shock. If you don't get poked. Turn one breaker on at a time. You know the drill.
  • Bad ground for sure. Check you extension cord. I just had this happen replaced extension cord problem solved!
  • Bad ground. Probably your adapter. It is quite common for them to fail.
