Yosemite Sam1 wrote:
Drain the overflow tub and the radiator and replace it with regular anti freeze from Walmart.
Or have Walmart do it for you.
If this is the Cummins ISC engine, that is very bad advice. Even for the B, it is not what Cummins recommends.
Read coolant specs in your Cummins manual or your chassis manual.
There are basically two kinds of approved coolants for diesels:
1. Low silicate for diesel with added SCA (Supplemental Coolant Additive)
2. The new generation long life coolants for diesels.
With a Cummins, I would sure look at the Fleetguard coolants, as that is Cummins in-house brand. If you ever need work at a Cummins shop, they will have the same coolant as you are using.
